11 years agoAccessing SRAM from NIOS and Verilog Module
Hi, I have implemented the Web Server example on the DE2-115 and modified it a bit to send data over ethernet to the DE2-115 board and store it in the SRAM. This data is around 1Mbit . Next I ...
11 years agoHi Mini@nB,
Thanks for the help. I have looked at the pdf you suggested and have a rough idea of what should be done. But I still don't know how I have to do it. Do you know of any example I can follow where something is exported from the Qsys system and used in a verilog module outside the system (for instance in an always block in the top level module). For starters I thought of blinking an LED from a verilog script instead of the NIOS system. It would be great if you could refer me to some example or manual that explains how something like this is done. I'm sorry if this is an extremely trivial task and my question sounds stupid. Thanks again!
