11 years agoAccessing SRAM from NIOS and Verilog Module
Hi, I have implemented the Web Server example on the DE2-115 and modified it a bit to send data over ethernet to the DE2-115 board and store it in the SRAM. This data is around 1Mbit . Next I ...
11 years agoThe external clock and GPIO pins need to be exported out of Qsys system by declaring them as conduit interface in the spec. If SRAM is Avalon-mm slave, you just plug and play the master (make the connection) and the Avalon fabric will do the rest for you. One more thing you have to include an additional Avalon-mm slave control interface in your module that instruct how/when to transfer data from the memory.
