11 years agoAccessing SRAM from NIOS and Verilog Module
Hi, I have implemented the Web Server example on the DE2-115 and modified it a bit to send data over ethernet to the DE2-115 board and store it in the SRAM. This data is around 1Mbit . Next I ...
11 years agoSGDMA IP might consume quite lots of resources and overkill for your simple requirement. If you're willing to spend some time studying avalon specification, it will be easy to build a custom GPIO module with avalon-mm master interface. Here's avalon specification https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/mnl_avalon_spec.pdf
