12 years ago --- Quote Start --- Q: About timing constraints of‘in2out’ timing path My design is as follows: file:///C:/Users/dell/AppData/Local/Temp/msohtml1/01/clip_image002.gif In my design, there are three ports: clk(system clock), ina(input port), outb(output port). My constraints are as follows: create_clock -period 10 -name my_clk [get_ports clk] set_input_delay -max 3 -clock my_clk [get_ports ina] set_ouput_delay -max 3 -clock my_clk [get_ports outa] set_max_delay 2 -from ina -to outb When Quartus tools analysis the 3rd timing path, the required time calculated as follows: 3(input_delay) + 3(output_delay) + 2(max_delay) + tdelay(com logic delay) <10(clock cycle) But I want to constraint the delay less than 2ns from ‘ina’ to ‘outb’, I don’t know how to constraint the timing path, could you please give me some advise for this case? Thanks wuyu --- Quote End --- May I ask what is the thinking here? you have an input (ina) going direct to output (outb) through some comb. logic that receives a registered version of ina(call it ina_r). So ina_r will get sampled at clock edge running every 10 ns yet you want ina to outb < 2ns???
