10 years agoabout time quest constraints
Hi to all. I have a little question. I have cyclonevgt dev board. I have to connect a D/A converter to pins of fpga. I create a PLL clock out 100Mhz, routed at a pin of fpga. I create a...
10 years ago --- Quote Start --- The external output clock pin (going to the dac) has name dac_clk, but does not appear in the clock list of timequest(get clocks). Must i declare the output pin of fpga as clock? how can I do? --- Quote End --- [create_generated_clock ...] and I don't remember syntax but there shoud be many examples around .
