10 years agoabout time quest constraints
Hi to all. I have a little question. I have cyclonevgt dev board. I have to connect a D/A converter to pins of fpga. I create a PLL clock out 100Mhz, routed at a pin of fpga. I create a...
10 years ago --- Quote Start --- you put your constraints in sdc file(edit by hand or through timequest). reference clock should be output clock that goes to DAC (not input clock to PLL) so you need to declare the output clock. --- Quote End --- Can you write here the sdc command, for max and min delays? Regards, Luca
