About loading constraints
- 2 years ago
The constraints you used will remove the Unconstrained path being reported out because the -to node (RLO_CLK_node) that is false path is the same.
At the end, designers need to know their design requirement and know where & when to use set_false_path. These constraints tell Timing Analyzer not to analyze specific paths or clock transfers. Once a path has been cut by either of these commands, there is no way to un-cut it, i.e. these constraints have the highest priority.
Richard Tan
Richard Tan
- Yamada12 years ago
Thank you for answering.
I understand that if the -to nodes are the same, the previous description and when using wildcards will have the same behavior.
In addition, there was a question about the purpose in the comment received at 1:02 AM on 3/18, but the purpose of setting a false path is to "exclude it from being analyzed by the timing analyzer."
Thank you very much for your detailed explanation of the details.
