Yamada1's avatar
Yamada1
3 years ago
About GPIO IP
I'm thinking of using the GPIO IP to receive the data output from the A/D converter to the FPGA at double rate. It would be helpful if you could teach me the following points. 1) On page 3 of the u...
  • FvM's avatar
    FvM
    3 years ago
    for differential IO standards like LVDS, I'd use option 2. Define a single ended port pin for the signal, assign differential IO in pin planner.
