8 years agoa10gx board installation failed
I follow to install,although at "Installing kernel driver module... " and "Installing board drivers..." gives "install: completed successfully" however there are some errors during insta...
8 years agoC:\Users\10611016\source>aocl install
Do you want to install C:\intelFPGA_pro\17.1\hld\board\a10_ref? [y/n] y aocl install: Running install from c:/intelFPGA_pro/17.1/hld/board/a10_ref/windows64/libexec +------------------------------------------------------+ + Performing initial checks... + +------------------------------------------------------+ +------------------------------------------------------+ + Installing kernel driver module... + +------------------------------------------------------+ WDREG utility v10.21. Build Aug 31 2010 14:21:54 Processing HWID *WINDRVR6 Installing a signed driver package for *WINDRVR6 CM_Get_DevNode_Status ret value 0, status 1802401, problem 1c LOG ok: 1, ENTER: DriverPackageInstallA LOG ok: 1, ENTER: DriverPackageInstallW LOG ok: 1, Looking for Model Section [DeviceList.NTamd64]... LOG ok: 1, RETURN: DriverPackageInstallW (0xE000024B) LOG ok: 1, RETURN: DriverPackageInstallA (0xE000024B) difx_install_preinstall_inf: err e000024b, last event 0, last error 0. UNKNOWN install: completed successfully +------------------------------------------------------+ + Installing board drivers... + +------------------------------------------------------+ WDREG utility v10.21. Build Aug 31 2010 14:21:54 Processing HWID PCI\VEN_1172&DEV_2494&SUBSYS_A1511172&REV_01 Installing a non-signed driver package for PCI\VEN_1172&DEV_2494&SUBSYS_A1511172&REV_01 Device node (hwid:PCI\VEN_1172&DEV_2494&SUBSYS_A1511172&REV_01): does not exist and is not configured. Pre-installing. LOG ok: 1, ENTER: DriverPackagePreinstallA LOG ok: 1, ENTER: DriverPackagePreinstallW LOG ok: 1, RETURN: DriverPackagePreinstallW (0xE000022F) LOG ok: 1, RETURN: DriverPackagePreinstallA (0xE000022F) difx_install_preinstall_inf: err e000022f, last event 0, last error 0. UNKNOWN install: completed successfully +------------------------------------------------------+ + ****** SUCCESS! Please reboot your system + +------------------------------------------------------+
