now if u don't have time or will to understand the decoder i will answer your questions :)
I should save the inputs using state machine with 3 states because the ordering of the input is not constant but changes according these states
I can't understand parallel storage idea isn't that what i am already doing i store the frame while operating on the previous one. that's what i am doing.
I think yes I should know my fmax but I should first know the delay of all computation engine blocks to do that.
I think now the main problem will be the memory issue and the fact that i can't use registers for that much of data if we assumed that the program will run correctly since i am getting a nasty error that i can't figure out which is
Error: Out of memory in module quartus_map.exe (2141 megabytes used)
Error: Current module quartus_map ended unexpectedly
i have posted earlier a thread asking for help and i have been given a link where there should be the solution to my problem but the link seems to be broken and not working
http://www.microsoft.com/whdc/system...ae/paemem.mspx (
http://www.microsoft.com/whdc/system/platform/server/pae/paemem.mspx)
