some points I can't understand
1.what do you mean by is the process sequential or combinational? isn't a process sequential always?
2.you told me before that when compiling the for loop the only effect if i was using one wire will be last one right? so in this case when i am using 128 computation engines doesn't this mean that only last 128 will have effect since I have 128 wires in this case?
3.now do you mean i have to create ram memory(using megafunction wizard or any way) instead of using these registers and dealing with addresses?:( or dealing with fpga kit memory which also i am not familiar with it very much?(I have startix 3 devolpment kit)
4.what do you mean by functional requirements?
