ok I think i missed a part to explain i am sorry
for this code
for i in 0 to 255
wire1<=syst_bit(i);
wire2<=parity1(i);
gamma(i)<=wire3;
end loop;
wire1 is the first input to the adder while wire2 is the second one while wire3 is the output
the block is as follows
wire1---| |
| adder |-----wire3
wire3---| |
and the equation i want to implement is
gamma(0)=syst_bit(0)+parity1(0)
gamma(1)=syst_bit(1)+parity1(1),.......for 256 times
so i am concerned about 2 things
1)is this operation in this form right and will work as i wish
2)will this operation cause timming problem because the real operation is not addition only but huge operations of adding,multiplication,comparing,normalizing,.... and should be done for constant number of times and i have a restriction to finish all this operations before 192 clocks are consumed(which is the time of constructing the new frame which i should do the same operation on)
Thanks in advance for your help
