9 years agoA question about the toggle in early power estimation (EPE)
Hi I have used the EPE tool based on excel. I cannot determine the value of the toggle. I have some questions about the toggle values. Are the toggle values in the "Logic", "Ram", "DSP", "IO" the ...
9 years agoIf you've started the creation of your project in Quartus, you can generate an EPE input file that can help in setting up the EPE. I forget if the option is in the Project menu or the File menu, but you can use that as a starting point.
