15 years agoA question about the asynchronous clear signal of dual clock FIFO
Hi, I used a MegaWizard generated dual clock FIFO in a design. FIFO width is 16 bits and its depth is 2048. The write and read clock of this FIFO is 90 MHz and 60 MHz respectively. Both of the...
15 years agoIf you're not writing to the FIFO out of reset, then you can put a false path on that. (set_false_path -from [get_keepers {reset_register_or_port}] -to [get_keepers {*dc_fifo_hierarchy*}]
Also make sure you're not reading, or that read protection is on(which is on by default). The aclr can be very short, so one pulse should be fine.
