14 years agosorry. I update word file so as to describe my question more explicitly. could you pls check attached word file again? thanks.
it seems that your methods are used to make sure data can't change within a window(setup+hold parameter of extern device) but those constraints in book are used to make sure data may change only within a window. BR, Fisher
