10 years agoA question about parameterized structure between interface and module
Hello everyone! I have a design that is using client/server architecture, one server module polling multiple client module periodically to check if the client module needs update, and if the clien...
10 years ago --- Quote Start --- This is exactly what a SystemVerilog interface is for.
interface# (int BITWIDTH_OF_SIG2) client_interface;
typedef struct packed {
logic sig1;
logic sig2; // BITWIDTH_OF_SIG2 is the parameter that should be passed from client or server module.
} client_info_t;
client_info_t info;
modport client(output info);
modport server(input info);
endinterface
module server_module (
client_interface.server client_port,
... // access client_port.info as an input
endmodule
module client_module (
client_interface.client client_port,
// ... // access client_port.info as an output
endmoduleThere is no longer a need to parameterize the client and sever modules. If they need it they can access it throu client_port.BITWIDTH_OF_SIG --- Quote End --- Hi, Mr.dave_59! Thank you for your patient replying! and I‘m so sorry about replying you much later! Indeed, I'm using 'interface' in my design, but the problem is a little more complex. The parameter which is used to parameterize the structure is generated as a localparam in client_module depends on some conditions and checkings (for I want to simplify the user interface of client_module by doing some automatic work), I want to pass it automatically by client_module's port list to the interface and server_module, just like this:
interface client_interface
logic sig1;
} client_info_t;
// modport client(output info); // I can't declare a modport for client_module, for there are multiple clients which will link to server. I think the modport should only be able to transmit ONE set of info generated by ONE client.
endinterface
module server_module(
endmodule
module client_module# (parameter SOME_CONDITION_DEFINED_BY_USER) (
output client_info_t info,
localparam VALOF_BITWIDTH_OF_SIG2 = SOME_CONDITION_DEFINED_BY_USER == 1 ? 32 : 16;
endmodule
Just as metioned above, for I want to link multiple clients to server, but I don't know how to transmit infoes from multiple clients to interface by a modport declared for client, I have to output the info from a port of client_module, instead of using modport for client, AND, I don't know how to reference a structure type defined in interface in client_module's port list. So I can't find any way to pass the 'VALOF_BITWIDTH_OF_SIG2' automatically. Even though the parameter declared at interface can instantiate the structure type, I don't know how to reference that structure type in client_module's port list, for the type is defined in interface, not global. If there was a way to implement, my problem could be resolved. So I thought if I could use parameterized structure, I could define the structure type in global range, and pass the 'VALOF_BITWIDTH_OF_SIG2' to that structure to meet the instantiated parent’s requirements such as 'client_interface' or 'client_module' etc. If it works, I can declare a parameter in interface which can be assigned with a compatible value with the client_module, and use the structure type 'client_info_t' which is defined in interface and instantiated by that parameter in interface and client_module's port list. But it seems to be impossible for Verilog and SystemVerilog haven't support parameterized structure yet, just as mentioned by Mr.Tricky, who replied me just before your replying. So, would you like to give me any more suggestion?
