10 years agoA question about parameterized structure between interface and module
Hello everyone! I have a design that is using client/server architecture, one server module polling multiple client module periodically to check if the client module needs update, and if the clien...
10 years agoThis is exactly what a SystemVerilog interface is for.
interface# (int BITWIDTH_OF_SIG2) client_interface;
typedef struct packed {
logic sig1;
logic sig2; // BITWIDTH_OF_SIG2 is the parameter that should be passed from client or server module.
} client_info_t;
client_info_t info;
modport client(output info);
modport server(input info);
endinterface
module server_module (
client_interface.server client_port,
... // access client_port.info as an input
endmodule
module client_module (
client_interface.client client_port,
// ... // access client_port.info as an output
endmoduleThere is no longer a need to parameterize the client and sever modules. If they need it they can access it throu client_port.BITWIDTH_OF_SIG
