10 years ago74LS190 Verilog Code
Hi. I'm a newbie in Verilog Programming. I wish to code using Verilog the functions of the 74LS190 which is simply an Up/Down Counter. Anyone who knows any code on this? It's basically a counter that will count up from 0-9 then back to 0 or count down from 9-0 then back to 9. 74LS190 is a Synchronous Up/Down BCD Decade counter. The state changes of the counters are basically synchronous with the LOW-to-HIGH transition of the Clock Pulse Input. Help please. Thanks.
Can you check if the code below is almost the same on what I am trying to find. module up_down_counter (count, D_in, load, count_up, cntr_on, clk, reset); output [2:0] count; input load, count_up, cntr_on, clk, reset; input [2:0] D_in; reg [2:0] count; always @ (posedge reset or posedge clk) if (reset==1'b1) count=3'b0; else if (load==1'b1) count=D_in; if (cntr_on==1) begin if (count_up==1'b1) count=count + 1; else count=count - 1; end endmodule Thanks!1 Reply
that looks like a standard updown counter...
