18 years agoHello,
I agree that "reserve unused pins as outputs tied to ground" could cause problems and probably shoulnd't been choosed as Quartus default option by Altera. But I think, it doesn't touch pins assigned otherwise. The issue is with pins having a particular hardware function but are yet unassigned in Quartus design. For this reason, I use "input with weak pullup" option (but sometimes, I may forget to change the option). Regards, Frank
