12 years ago4x4 keypad matriz
the only problem with the code is the problem with the keyboard rebounds and do not know how to fix it if someone could help me with the code would greatly appreciate it since I am on a project and I could not move through this jam that I have
my code: ---------------------------------------------------------------------- LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; entity teclado is port( clock,rst : in std_logic; col_line : in std_logic_vector(3 downto 0); fila_line : out std_logic_vector(3 downto 0); display : out std_logic_vector(6 downto 0) ); end teclado; architecture archi_teclado of teclado is signal temp : std_logic_vector(29 downto 0); CONSTANT max: INTEGER := 50000000; signal clkout: std_logic; --CONSTANT med: INTEGER := max/2; CONSTANT half: INTEGER := max/50000; SIGNAL count: INTEGER RANGE 0 TO half; signal temp1: INTEGER RANGE 0 TO 16; begin PROCESS BEGIN WAIT UNTIL clock'EVENT and clock= '1'; IF (count < max) THEN count <= count + 1; ELSE count <= 0; END IF; IF (count < half)THEN clkout <= '0'; ELSE clkout <= '1'; END IF; END PROCESS; key_driver: process(clkout,rst,temp,temp1) begin if(rst='0') then temp1<=16; elsif (clkout'event and clkout='1') then temp <= temp + 1; -- retraso:=retraso+1; case temp(10 downto 8) is when "000" => fila_line <= "0111"; --1 fila when "001" => if col_line = "0111" then -- display <= "0110000"; -- 3 temp1<=13; elsif col_line = "1011" then -- display <= "0100100"; -- 2 temp1<=15; elsif col_line = "1101" then -- display <= "1111001"; -- 1 temp1<=0; elsif col_line = "1110" then -- display <= "1000000"; -- 0 temp1<=14; end if; when "010" => fila_line <= "1011"; -- 2 fila when "011" => -- if (delay='1') THEN if col_line = "1110" then -- display <= "0011001"; -- 4 temp1<=7; elsif col_line = "1101" then -- display <= "0010010"; -- 5 temp1<=8; elsif col_line = "1011" then -- display <= "0000010"; -- 6 temp1<=9; elsif col_line = "0111" then -- display <= "1111000"; -- 7 temp1<=12; end if; -- end if; when "100" => fila_line <= "1101"; -- 3 fila when "101" => -- if (delay='1') THEN if col_line = "1110" then -- display <= "0000000"; -- 8 temp1<=4; elsif col_line = "1101" then -- display <= "0010000"; -- 9 temp1<=5; elsif col_line = "1011" then -- display <= "0001000"; -- a temp1<=6; elsif col_line = "0111" then -- display <= "0000011"; -- b temp1<=11; end if; -- end if; when "110" => fila_line <= "1110"; --4 fila when "111" => -- if (delay='1') THEN if col_line = "1110" then -- display <= "1000110"; -- C temp1<=1; elsif col_line = "1101" then -- display <= "0100001"; -- d temp1<=2; elsif col_line = "1011" then -- display <= "0000110"; -- e temp1<=3; elsif col_line = "0111" then -- display <= "0001110"; -- f temp1<=10; end if; --end if; when others => null; end case; END IF; CASE temp1 IS when 0 => display <="1000000"; when 1 => display <="1111001"; when 2 => display <="0100100"; when 3 => display <="0110000"; when 4 => display <="0011001"; when 5 => display <="0010010"; when 6 => display <="0000010"; when 7 => display <="1111000"; when 8 => display <="0000000"; when 9 => display <="0010000"; when 10 => display <="0001000"; when 11 => display <="0000011"; when 12 => display <="1000110"; when 13 => display <="0100001"; when 14 => display <="0000110"; when 15 => display <="0001110"; when 16 => display <="ZZZZZZZ"; end case; end process key_driver; end archi_teclado;
