13 years ago
4bit siso shift register
I used the following code for 4bit siso shift register.
Signal temp : std_logic_vector( 3downtown 0);
begin
process
begin
if(rising_edge(clk)) then
temp(3 downtown 1)<=temp(2 downto 0);
temp(0)<=si;
end if;
end process;
so<=temp(3);
end behavioural;
I used the following testbench code.
clk<= '0';
si<='1';
wait for 100ns;
clk<= '1';
si<='1';
wait for 100ns;
But after stimulation its shows that so is undefined i.e
a red bar is shown....
Pls help......
    You only show a single clock in the testbench code. It will take 4 clocks for si to propogate to so.
    clk<= '0';
    si<='1';
    wait for 100ns;
    clk<= '1';
    si<='1';
    wait for 100ns;
    clk<= '0';
    si<='1';
    wait for 100ns;
    clk<= '1';
    si<='1';
    wait for 100ns;
    clk<= '0';
    si<='1';
    wait for 100ns;
    clk<= '1';
    si<='1';
    wait for 100ns;
    clk<= '0';
    si<='1';
    wait for 100ns;
    clk<= '1';
    si<='1';
    wait for 100ns;
    I have used the above coding.....
    Even if I use 4 clocks its still shows the red bar
    did you try to initialize temp(3 downto 0) to an initial value? If not you need at least 4 clock edges to get "so" "green"
    if "red" it would be that you never put anything on it...
