8 years ago3 wire spi data transfer
Hi I am using 3 wire SPI IP from the prime Software. I didn't found any document which says how to pass the data or how to use this IP. In this IP, Input side 3 wire SPI IP, which is A...
8 years agoChapter 5 of the "embedded peripherals ip user guide (https://www.altera.com/en_us/pdfs/literature/ug/ug_embedded_ip.pdf)" covers Altera's SPI IP core. See table 21 for the register map which you access via the Avalon MM interface.
Cheers, Alex
