#287035 problem
when i use "abs" Quartus has Errors
Error (287035): Text Design File must contain a Subdesign and Logic Section
Error (12006): Node instance "add_sub_15" instantiates undefined entity "add_sub_fpc"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 2 errors, 1 warning
Error: Peak virtual memory: 4715 megabytes
Error: Processing ended: Sun Dec 08 12:25:24 2019
Error: Elapsed time: 00:00:36
Error: Total CPU time (on all processors): 00:00:28
Error (293001): Quartus II Full Compilation was unsuccessful. 4 errors, 1 warning
like this
elsif(cal_result < 0 and cal_result > -10) then
num1_1 <= 20;
num1_2 <= 20;
num1_3 <= 20;
num1_4 <= 20;
num1_5 <= 18;
num1_6 <= (abs(cal_result) mod 10);
this is my code
1 Reply
- KhaiChein_Y_Intel
In a Text Design File (.tdf), you did not use a Subdesign Section or Logic Section. A TDF must contain both a Subdesign Section and a Logic Section. You cannot declare these sections in a separate AHDL Include File (.inc) and then try to include them in a TDF using an Include Statement.
You have to make sure that the TDF contains both a Subdesign Section and a Logic Section. Do not declare the Subdesign Section or Logic Section in a separate AHDL Include File.
