13 years ago20ns pulse generation at rising edge
I'd like to generate a 20ns high signal at the rising edge of another (clocked, 330ns) signal. Formally, they are a 50MHz clock and a 3MHz clock. Right now, I am stuck at the very beginnin' of this task. I mean, I found many codes that can generate a pulse if a rising edge condition is meet. Anyway, there's no control on the pulse duration. I was thinking of a signal locked at the rising edge of the 3Mhz signal to trigger a state machine clocked @50Mhz. My problem is that I can't figure out how to deassert the trigger signal, since it will deassert on the next rising edge of the control signal. Here is a (wrong) code I made since now - i didn't include resets here to make it easibily readable. I don't expect a solution, or it to work. I'd like just a hint. --- Quote Start --- always@(posedge 3Mhz_signa) begin up<=1; end always@(posedge 50Mhz_signal) begin case(fsm) 0:begin; data_out<=0; if up(fsm<=1); end 1:begin; data_out<=1; fsm<=0; end endcase endmodule --- Quote End --- how can i deassert "up" signal after 20ns, being locked to posedge 3Mhz clk? I was thinking of a sort of "feedback", but still not ideas. EDIT: i seems like I didn't search enough on google. I found out this (http://www.oldcrows.net/~patchell/iparchive/oneshot.v) that's exactly what I needed. Basically, feedback was the right way. I've a long way to proper learn coding.
