DMcla2
8 years ago209012 Error When Programming .pof
Hello, I am using a USB Blaster II to program my MAX10 and am having difficulties with the .pof(see attached). The .sof program is consistently successful, but for whatever reason the .pof is failin...
Nooraini_Y_Intel
7 years agoHi David,
Thanks for the update. It's good to know that you were able to resolve the issue. Hopefully this issue does not reoccur. FYI, even for MAX 10 JTAG setup the nCONFIG, nSTATUS and CONF_DONE are still are still require to be pull up to VCCIO voltage level via 10kohm pull up. The nCONFIG, nSTATUS, CONF_DONE and JTAG are different pins in MAX 10 device family. You can refer to chapter 3.2.3. JTAG Configuration Setup in the following MAX 10 device Configuration user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Nooraini
