DMcla2
8 years ago209012 Error When Programming .pof
Hello, I am using a USB Blaster II to program my MAX10 and am having difficulties with the .pof(see attached). The .sof program is consistently successful, but for whatever reason the .pof is failin...
DMcla2
7 years agoI am using JTAG programming mode, not active/passive serial modes. As such the CONF_DONE is treated as TDO and it is recommended by Intel to leave TDO connected to appropriate MAX10 pin with no pull-ups/pull-downs:
NOTE: Per the guideline referenced above, my config voltage exceeds 2.5V, so I have a 10pF cap loading that TDO line.
VCCIO Bank 1B Voltage: 3.3V
There are no other devices loading down that TDO line in my design.
-David
