DMcla2
8 years ago209012 Error When Programming .pof
Hello, I am using a USB Blaster II to program my MAX10 and am having difficulties with the .pof(see attached). The .sof program is consistently successful, but for whatever reason the .pof is failin...
Nooraini_Y_Intel
8 years agoHi DMcla2,
Is the CONF_DONE correctly pull up to VCCIO Bank1 voltage level via 10kohm pull up? What is the VCCIO Bank 1 voltage level? Make sure there are no other component (such as LED) holding the CONF_DONE low. Only connect the CONF_DONE via 10kohm pull up to VCCIO Bank1 voltage level.
Nooraini
