CHatz
5 years ago14566 The Fitter cannot place 5 periphery component(s) due to conflicts with existing constraints
In Platform Designer, for the Arria 10 Hard Processor System, in Tab "IP Selection", I have set GPIO = 5.
In Tab "Advanced Pin Placement", for HPS Shared I/Os, I have the following selections:
Q1...
sstrell
5 years agoSince those are dedicated pins for the HPS that you specify in the HPS IP parameters, I'm not sure if you need the location assignments. Did you try removing them?
