9 years ago13410 pin stuck at GND, but simulation ok
Hi there, I'm getting the compile error "13410 Pin led_col_ctrl[n] is stuck at GND" on 15 pins of a 36 pin output vector. When I simulate the design in modelsim these same pins work as expected (i.e...
9 years agoI compiled your project with Quartus II 15.0.2 and did not get any "stuck at GND" messages. Restore your project from the .qar file and recompile it. If the errors are gone then you probably had a corrupt database in the original project. Try cleaning the project (Project -> Clean Project from menu) or just delete the "db" folder in the project folder.
