16 years ago
.qsf file
I'm trying to find out the meanings of these informations located in the .qsf file :
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_global_assignment -name LL_ROOT_REGION ON -section_id "Root Region"
set_global_assignment -name LL_MEMBER_STATE LOCKED -section_id "Root Region"
I looked into the .qsf reference mnl but it doesnt contain any description.
Could you explain me what does each sentence do ?
Julien.
    --- Quote Start ---
    Julien.
    --- Quote End ---
    Hi Julian
    all this settings are Quartus default settings for design partitions.
    # Defines a design partition for your toplevel
    # Defines the source for the Quartus run. In this case the source files will be used.
    # Defines the color for the design partition in the "Chip Planner" tool. That is a floorplan view.
    # It is recommended to define a LogicLock region for a partition and lock them down. As default the LogicLock region contains the whole device.
    Kind regards
    GPK
