8 years ago.qip file missing in Symbol window?
Hi, I am using Quartus Web edition (14.1 : Free edition). Started learning : How to create custom Qsys component. So i have following the link :https://www.youtube.com/watch?v=z6tmpwwxik0 ...
8 years agoI can't see your picture, but the key is the .bsf file generated, not the .bdf (.bsf is a symbol file, .bdf is a full design schematic file). When you generate the system, make sure you enabled the creation of the .bsf symbol file. Then, the .qip added to your Quartus project should point to the .bsf and then that should appear in the schematic editor.
If it still doesn't work, copy the .bsf file to your project directory. Maybe then the project will see it so you can add it to a schematic.
