18 years ago.JIC file Generation
Hi all,
I wish to generate JIC file with NIOS firmware + Logic to configure EPCS and using command line, so I did a script to do this. 1) Convert SOF to Flash sof2flash --epcs --input=$sof --output=hw.flash --quiet 2) Convert ELF to Flash elf2flash --epcs --after=hw.flash --input=$elf --output=sw.flash 3) Concatenate cp hw.flash hw_sw.flash cat sw.flash >> hw_sw.flash 4) Create HexFile nios2-elf-objcopy --input-target srec --output-target ihex hw_sw.flash $hex So, after I need to use Quartus->File->Convert Programming Files... to generate JIC using EP3C25 Device, EPCS128 (I'm using Spansion 128Mbit) and after Programmer to download. I search by quartus_cpf in command_line reference, but I didn't find any references to convert hex to jic, only sof. Anybody can help with other way to create JIC (its usefull to send file to production line) or say where I'm misunderstanding :) ? Thx, Veiga Quartus 8.0
