16 years ago --- Quote Start --- Hi pletz, yes, I copied it in there. I tried to write down the exact procedure how I set everything up in my opening post. I have two file in my "project_root/Filter"-folder: filter.vhd and filter.bsf. The filter.bsf I had to copy in that folder, too, after I created it because Quartus put it into the "project_root" path. I really wonder why this is such a big problem for me because I thought if I put it into the library search path of my project everything should be fine . . . Maik --- Quote End --- Hi Maik, I have a project to my last post attached. Please have a look to it. Is that what you are doing ? Kind regards GPK
