16 years agoHi pletz,
yes, I copied it in there. I tried to write down the exact procedure how I set everything up in my opening post. I have two file in my "project_root/Filter"-folder: filter.vhd and filter.bsf. The filter.bsf I had to copy in that folder, too, after I created it because Quartus put it into the "project_root" path. I really wonder why this is such a big problem for me because I thought if I put it into the library search path of my project everything should be fine . . . Maik
