16 years ago --- Quote Start --- Hi pletz, thanks for your reply! Well, I thought that if I added the "project_root/Filter"-folder to my library path, I don't need to add the files to my project. . . . Maik --- Quote End --- Hi Maik, that should work. Maybe a stupid question, did you copy your vhd file in the Filter folder ? If have a small project attached. Is that what you are doing ? Kind regards GPK
