16 years ago --- Quote Start --- Hi, I have an IIR filter design created and exported as *.vhd with Matlab. I copied this .vhd file into a folder in my current Quartus II project which I called say "Filter". So the structure is now project_root/Filter. Now, I opened this .vhd-file in my current Quartus project (not added it, just opened) and I created a symbol file from it by clicking "File/Create_Update/Create Symbol files for current File". The created .bsf file I copied fom project_root to project_root/Filter. Then I put the project_root/Filter path to the Project libraries. Now, when I add a new .bdf File to my project and I put in there my just creates filter-.bsf symbol. I can't open the design file by double clicking on the symbol file. I just get the message "Cannot locate design file for entity "Filter"". What have I done wrong or how is the normal procedure to create a bsf file? Regards, Maik --- Quote End --- Hi Maik, I would guess you have to use the "add file" function for both files, the bsf and the vhd file. Kind regards GPK
