dsun01
Contributor
4 years ago# ** Error: invalid command name "top_system_tb::get_env_variables"
Dear Intel Support/FPGA Expert
I opened AN812 top_system.qsys with Quartus pro 21.3, using Platform Designer Generate Testbench, then I use Questa, change directory to top_system_tb/sim/mentor. do...
YEan
Contributor
4 years agoHi David,
Do you mind to share the file for me to check it? By reading the error message, it seems like the command in msim_setup.tcl is invalid. You may try to change this command "top_system_tb::get_env_variables" in your script.
Ean
