RGuzm4
7 years ago¿Por qué Quartus II no corre "Run funtional simulation" o "Run timing simulation"?
Buenas tardes, estoy teniendo un problema para simular mi programa en Quartus II. Cuando genero el archivo .vwf, cuando presiono "Run funtional simulation" o "Run timing simulation", no sucede nada, no se abre ninguna ventana que muestre un error, no realiza ninguna acción
- RGuzm4
luckly I solved it, I erased all the blank spaces and special characters form the directory of the file and it worked, thanks for the help anyway
- CalvinJoaz_P_Intel
Contributor
Hi Rodrigo,
Good day to you.
Kindly provide the information as below.
- Which device you're using?
- Which Quartus II version you're using?
- Print screen of the following error.
Thank you.
