請問quartus lite版有支援到windows 11?
請問我目前使用macbook pro有安裝微軟視窗 win11家庭版,並也安裝quar lite版
寫完程式要編譯都會失敗.以下是它的錯誤
Problem Details
Error:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270
Stack Trace:
0x48b8c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID::operator unsigned __int64 + 0x2bb4c (DDB_DYGR)
0x1e780: std::_Hash<std::_Umap_traits<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,std::_Uhash_compare<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID> >,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> >,0> >::_Hashval + 0x10 (DDB_DYGR)
0x1fc3e: std::unordered_map<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> > >::operator[] + 0x1e (DDB_DYGR)
0x1db2b: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xff (DDB_DYGR)
0x189d6: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x66 (DDB_DYGR)
0x3433b: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x83 (DDB_DYGR)
0x15360: DYGR_DIE_INFO_BODY::load_data + 0x2a4 (DDB_DYGR)
0x1d1f7: MPP_ROOT::start + 0x587 (COMP_MPP)
0x5e5a: qfit_execute_mpp + 0x42 (comp_qfit_legacy_flow)
0x555b: QFIT_FRAMEWORK::execute + 0x22f (comp_qfit_legacy_flow)
0x2768: qfit_legacy_flow_run_legacy_fitter_flow + 0x1d4 (comp_qfit_legacy_flow)
0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
0x17a65: TclEvalEx + 0xa65 (tcl86)
0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5646: Tcl_EvalFile + 0x36 (tcl86)
0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
0x11ac3: qexe_do_tcl + 0x343 (comp_qexe)
0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
0x1658d: qexe_run + 0x39d (comp_qexe)
0x17371: qexe_standard_main + 0xc1 (comp_qexe)
0x2262: qfit2_main + 0x82 (quartus_fit)
0x13258: msg_main_thread + 0x18 (CCL_MSG)
0x14a5e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
0x2a02: __tmainCRTStartup + 0x10e (quartus_fit)
0xeb93b: uaw_wcsrchr + 0xe5e7b (KERNEL32)
0x71ef7: uaw_wcsrchr + 0x6c437 (KERNEL32)
0x1bcb6f: NtWaitLowEventPair + 0x1ae5df (ntdll)
End-trace
Executable: quartus_fit
Comment:
windows 11
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.1
Build: 720
Edition: Lite Edition
- SyafieqS
Hi Aaron,
Quartus does not support win 11 yet, I'm afraid that's prolly be the reason for you error.
Please use proper requirement you may refer to link below for more detail regarding it.
- aaron88
你好謝謝,我已知道目前不支援win11
想請問英特爾開發quar軟體什麼時候?會支援到win11 os,謝謝
- SyafieqS
May I know if there is any update?
- SyafieqS
We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- aaron88
你好,目前不打算使用Windows 10 os,所以想請問
英特爾開發quar軟體什麼時候會支援到win11 os,謝謝
