10 years agoYoctoPlugin SoCKit Altera Cyclone 5
Hello everyone. I have an issue when I try to build image via bitbake command of Yocto Project.
I did follow this guide of Altera http://download.altera.com/akdlm/software/soceds/cb/embedded_linux_getting_started_guide.pdf The error come when I use this command to build image bitbake virtual/kernel virtual/bootloader altera-image I'm using Ubuntu 16.04 LTS. I searched in the Internet and some people say that error because the version of my Ubuntu distribution I'm using. I'm so confuse now. Please help me. Thanks OEROOT=/home/hohaidang/yocto # ## Shell environment set up for builds.# ## You can now run 'bitbake <target>' Common targets are: bitbake virtual/kernel bitbake virtual/bootloader bitbake altera-gsrd-image bitbake altera-image hohaidang@hohaidang-PC:~/yocto/build$ bitbake virtual/kernel virtual/bootloader altera-imagePseudo is not present but is required, building this first before the main build WARNING: Host distribution "Ubuntu 16.04.1 LTS" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution. Loading cache: 100% |#######################################################| ETA: 00:00:00 Loaded 1174 entries from dependency cache. Parsing recipes: 100% |#####################################################| Time: 00:00:01 Parsing of 878 .bb files complete (857 cached, 21 parsed). 1202 targets, 111 skipped, 0 masked, 0 errors. Build Configuration: BB_VERSION = "1.16.0" TARGET_ARCH = "arm" TARGET_OS = "linux-gnueabi" MACHINE = "socfpga_cyclone5" DISTRO = "poky" DISTRO_VERSION = "1.3" TUNE_FEATURES = "armv7a vfp neon callconvention-hard cortexa9" TARGET_FPU = "vfp-neon" meta meta-yocto meta-yocto-bsp meta-yocto-bsp meta-altera meta-linaro = "<unknown>:<unknown>" NOTE: Resolving any missing task queue dependencies NOTE: Preparing runqueue NOTE: Executing SetScene Tasks NOTE: Executing RunQueue Tasks ERROR: Function failed: sysroot_stage_all (see /home/hohaidang/yocto/build/tmp/work/x86_64-linux/quilt-native-0.60-r0/temp/log.do_populate_sysroot.7796 for further information) ERROR: Logfile of failure stored in: /home/hohaidang/yocto/build/tmp/work/x86_64-linux/quilt-native-0.60-r0/temp/log.do_populate_sysroot.7796 Log data follows: | DEBUG: Executing python function sstate_task_prefunc | DEBUG: Python function sstate_task_prefunc finished | DEBUG: Executing python function do_populate_sysroot | DEBUG: Executing shell function sysroot_stage_all | tar: '--same-order' cannot be used with '-c' | Try 'tar --help' or 'tar --usage' for more information. | tar: This does not look like a tar archive | tar: Exiting with failure status due to previous errors | DEBUG: Python function do_populate_sysroot finished | ERROR: Function failed: sysroot_stage_all (see /home/hohaidang/yocto/build/tmp/work/x86_64-linux/quilt-native-0.60-r0/temp/log.do_populate_sysroot.7796 for further information) ERROR: Task 10 (/home/hohaidang/yocto/meta/recipes-devtools/quilt/quilt-native_0.60.bb, do_populate_sysroot) failed with exit code '1' NOTE: Tasks Summary: Attempted 23 tasks of which 22 didn't need to be rerun and 1 failed. No currently running tasks (7 of 63) Summary: 1 task failed: /home/hohaidang/yocto/meta/recipes-devtools/quilt/quilt-native_0.60.bb, do_populate_sysroot Summary: There was 1 WARNING message shown. Summary: There was 1 ERROR message shown, returning a non-zero exit code.1 Reply
I found out by finding a post that Ubuntu 14.04 and above are only supported by Yocto 1.6 and above:
https://www.mail-archive.com/[email protected]/msg18678.html Here you can get a newer version and be successful https://www.yoctoproject.org/downloads
