12 years agoYet an other QSPI booting problem
I'm attempting to boot my project from QSPI on the Arrow SoCKit development board (Cyclone V), but the preloader is not loaded correctly into on-chip ram by the boot rom. The preloader is build...
12 years agoI followed the Arrow SoCKit recipies on rocketboards.org. I still don't know what went wrong, but without any apparent change in the procedure I'm now able to boot from QSPI.
Regarding debugging of the BootROM I simply used DS-5 and the USB blaster JTAG interface in the SoCKit dev board. To connect to the target during "cold start" I did the following: 1) press and hold down both the HPS_RST and the WARM_RST buttons. ( they are connected to HPS_NPOR and HPS_RST respectively) 2) release only the HPS_RST button 3) connect to the target via the DS-5 debugger. Use a "debug configuration" that only connects to the target. 4) issue the debugger command "interrupt" 5) release the WARM_RST button This catches the target at address 0x0, and from there you can single step through the BootROM. Jesper
