12 years agowriting vhdl code in nios ii processor
Hello everyone. I am currently doing a project on cyclone iii fpga starter kit. In my project I made a counter that counts calue from 0 to 10. I want to first write these values in ssram by pressing ...
12 years agoHi, you can post your code within [ code] balises
(just a detail : std_logic_unsigned is NOT an IEEE package, but you can use it) Your code is .... good for Halloween :-) for the process, you want a synchronous process so write
process(reset, clk) -- nothing else
-- variables if any
begin
if reset = '1' then
-- asynchronous variables and signals initializations here
elsif rising_edge(clk) then
end if;
end process;
You should name "re_n" and "we_n" since they are active low. You inferred a RAM... it is just an internal RAM to your counter, that will be difficult to read from QSYS What's happen You inferred unwanted(?) delay : ram(waddr) ----> count ----> q. So you q is assigned after 2 clocks. All is quite confused. ------------------ I suggest(only suggest) you to write a simple counter like this process(reset, clk) -- nothing else
begin
if reset = '1' then
count <= 0; -- if count is integer with range 0 to 9
if count < 9 then
count <= count +1;
else
count <= 0;
end if;
end if;
end process;
and then connect the "count" signal to a PIO for QSYS. In software, just read the PIO : IORD_ALTERA_AVALON_PIO_DATA(PIO_COUNTER);
