14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years agohi, Tiakumosan,I'm tring to writing a txt file to the sd card,but if the file is larger than 4k, I get problem. I can't open the file in windows,even use the winhex, it tells that can't read the *.txt file . wish your help.thanks
