14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years agoHello! I successfully create a file in my SD card! I only having problems to write in the file! I am doing some tests I post my results when I get something.
Here is my C program: # include <stdio.h> # include <altera_up_sd_card_avalon_interface.h> # include <altera_avalon_pio_regs.h> int main(void){ alt_up_sd_card_dev *device_reference = NULL; int connected = 0; short int arquivo = 0; short int att = 0; char data = 0; printf("Insira o SD Card \n"); device_reference = alt_up_sd_card_open_dev("/dev/Altera_UP_SD_Card"); if (device_reference != NULL) { while(1){ if((connected ==0) && (alt_up_sd_card_is_Present())){ printf("SD Card Connected. \n"); IOWR_ALTERA_AVALON_PIO_DATA(LEDR_BASE, 0xFFFF); if(alt_up_sd_card_is_FAT16()){ printf("FAT16 file system detected!!! \n"); /* Start to create a file */ arquivo = alt_up_sd_card_fopen ("file.txt", true); printf ("fopen returns: %d\n", arquivo); alt_up_sd_card_write(arquivo, data); att = alt_up_sd_card_get_attributes(arquivo); printf ("get_attrubutes return: %d\n", att); /*alt_up_sd_card_fclose(arquivo);*/ /* End */ } else{ printf("Unknown file system. \n"); } connected = 1; } else if ((connected == 1) && (alt_up_sd_card_is_Present() == false)){ printf("SD disconected. \n"); IOWR_ALTERA_AVALON_PIO_DATA(LEDR_BASE, 0); connected = 0; } } } return 0; }
