14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years agoI just solved my problem and it seems that my altera_up_sd_card_avalon_interface.h and altera_up_sd_card_avalon_interface.c files were outdated. I replaced my files with the ones at ftp://ftp.altera.com/up/pub/altera_material/11.0/university_program_ip_cores/ and now it seems to read my files correctly.
Another problem I had was when trying to read characters with value above 127, because the alt_up_sd_card_read returns a short int. Then, I changed its return value to int on altera_up_sd_card_avalon_interface.h and altera_up_sd_card_avalon_interface.c, and at the former, I changed: * Line 1733 from (char) to (int); * Line 1680 from char to int; That resolved my problems, and now I can read values above 127.
