14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years ago --- Quote Start --- PeteCSI: I'm having some trouble when creating a NIOS with the Altera_UP_SD_Card, I tested the .c example using a Nios from the Altera CD, but I get no response from SD. --- Quote End --- GP150, are the hardware you created right? I followed the instructions on PDF from University Altera and it is detecting the SD card.
