14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years agoYou'll need quite a lot of USB driver code in order to access a USB drive.
You'll also need fairly trivial (by comparison) code to access the FAT32 filesystem on the device.
