14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years agoIf you always run your system with a USB cable attached, you could use the host file system software component, that will let you read/write files on the PS from the embedded application. You need to run in debug mode though.
