14 years agoWriting .txt file in SD Card - DE2
Hello, I am Student from a University beginner in FPGAs, and I was doing a project with Nios II that uses a Altera DE2 Board to do some operations and save the results. The main ideia was to transmit...
14 years agoWhen I transfer data, I use a very simple and relatively fast connection via GPIO and Labview. For that you need a Labview card and box (expensive but in most university labs available) with digital I/O pins and a clock input. Then you connect the I/O pins from Labview to some pins of the GPIO port.
The transfer rate is 1Mbit/s for each connected data pin with my labview card. I tried to write to the SD card once, but failed when my SD card was not even recognized by the board. There is also no example to actually write to the SD card, only to read from it.
