14 years agoWriting to SRAM
Hi everyone, Does anyone have a tutorial that shows me how to write to Memory using SOPC? Thanks
14 years ago --- Quote Start --- That should work fine. Its very difficult to read code and see bugs (other than the obvious). You should really create a simulation and see if the code responds correctly to serial characters on its input and generates them on its output. Cheers, Dave --- Quote End --- Thanks Dave, you are the best :) I have tested the transfer with few characters, it works perfect. The problem is when I transfer a big file. Sometimes, it works fine and transfer 100% of the file. Sometimes, it transfer 80% of the file?!! so I think I want to switch to Nios, let me try the tutorial link you sent me and get back to you on this. Mona
